Just a quick question,does the 8 yard 6 oz glass sheet have to be cut for the cockpit the instruction book says there are three sheets but only have two a 4 oz and an 8oz. The sheet seems long enough to cut a 5' piece off for the cockpit. Thanks in advance for you answers
RE: Ch 17 6oz glass sheet
Thank you for your reply! Just wanted to make sure I wasn't missing a third sheet before I start cutting.
» Submitted by hspira - Mon, 5/10/21 » 11:18 PM
there will only be two sheets. 8 yards of 6 oz and 3 yards of 4 oz glass.
the eight yards of 6 oz will do the hull and cockpit.
the 3 yards of 4 oz glass will do the deck (you will need to cut the 4 oz cloth it into two pieces - one which will do the deck from the cockpit forward and one for the deck from cockpit to the stern.)
i hope that helps/makes sense
