WHEN APPLYING THE FIRST COAT OF EPOXY OVER THE FIBER GLASS CLOTH, I MISTAKENLY USED ONLY HARDENER--NO EPOXY, ON A SMALL AREA. I THEN USED ACETONE TO TRY TO GET THE HARDENER OUT OF THE FIBERGLASS & WOOD ON A SIDE BOARD. SEEMED TO ALL COME OUT & FELT DRY. I THEN RECOATED THE AREA WITH CORRECTLY MIXED EPOXY & HARDENER, & ALL SEEMED WELL. WENT ON TO FINISH THE ENTIRE KAYAK WITH 2 COATS. LOOKED GOOD & FELT HARD. A WEEK OR SO LATER SEVERAL SMALL SPOTS IN THE FIXED AREA HAVE BLISTERED. ANY INFORMATION ON WHAT TO DO NOW WOULD BE OF GREAT HELP.
