joining bungees
Finally fitting out our pair of much loved wood ducks, has anyone come up with a more elegant way of joining the bungees rather than the ugly knot ?
RE: joining bungees
A knot has this advantage: you can untie it to re-varnish.  If you are using the disappera-into-the-hull type bungee I suppose you could tie the knot under the deck, so above deck would be nothing but smooth bungees.  I used a water knot, though a double fisherman's knot is standard.
RE: joining bungees
The slickest method I've seen is the one described by Joe Greenley of Redfish Kayaks.  I've used it, and years later the bungees are still holding.  Here's a link to a post where he describes his technique:
http://www.kayakforum.com/cgi-bin/Building/Archive50.pl/noframes/read/54933
Ross
RE: joining bungees
You can get some plastic (nylon maybe) hooks from West Marine that clamp onto bungee.  I put a hook on each end and hook them together.  It looks great.
Paul G
RE: joining bungees
I agree with Ross. I glued the bungies and that was five years ago for one boat and four years ago for the other. this year I am refinishing both boats and I will just cut the bungees and replace. It is time now that the UV has started to takes measure.
