I just glassed the bottom of my board and discovered three white spots - there werent air bubbles and these are maybe less than 2x2 inches. Way too big for air. Aside from these the epoxy looks awesome like glass.
Can i fix this? I am waiting for it to dry a bit further before flipping and doing top and want to avoid these insightly things else its going to be a painted board? Dunno...
RE: White spots
Sounds like maybe contaminated cloth that didn't wet out properly. Joe's fix will totally solve that.
RE: White spots
I should add that as you sand the epoxy, the fill can look alarmingly conspicuous. Once you cover it with a new coat it will seem to disappear.
RE: White spots
» Submitted by turnAround! - Mon, 7/12/21 » 2:25 PM
I recently had a few white spots on my Teardrop and they didn't go away even when I squeezed the epoxy with my fingers. I let the fiberglass cure, sanded dimples through the fiberglass down to the wood until the spots were gone, filled the divots with a smidge of fiberglass and several drops of epoxy, sanded, and repeat until I got back to level. Looks fine now.
