poor adhesion on onlay causing bubble
Has anyone had a problem with the sun (heat) causing a bubble under an onlay and is there a way of fixing it? Can i some how get epoxy under without too much damage?
Yacko
RE: poor adhesion on onlay causing bubble
I just wanted to add a caution here. Possession of the needles for such syringes in the manner described, or via purchase from an online woodworking supplier, is a felony in several states.
» Submitted by David.Donaldson - Tue, 6/23/09 » 7:39 AM
I have done this with vaneer on furniture, not had the same issue with onlays but should work. Use a syringe to inject some glue underneath the onlay, then using saran warp or wax paper put some weight on top to "clamp" it down.
http://www.leevalley.com/wood/page.aspx?c=&p=20003&cat=1,110,42967
They are cheaper if you know someone in the medical field... I usually just "borrow" one from my vet when he is visiting the barn.
