Inhave built a 14 kahalo and skerry already. I cannot conch the bow because the first frame appears to wise. If i cinch it will crack the plywood for sure.
Can someone share dimensions of the number one frame and the position of the holes on the sideboards? I believe i recieved the frames for the 14 foot board but am building a 12 foot one. The holes drilled are in the middle of the side board va on bottom to cinch the notch. And my stern piece is not notched. Maybe i got a blended kit half 12 and half 14? Scratching my head ...
1 reply:
RE: Kahalo
» Submitted by Mark N - Wed, 9/14/22 » 7:22 PM
I built a 12.5 hybrid for my bride a couple of years ago. The board is complete so I cannot give you exact measurements. The side stitch holes are located ~17.5" back from the tip of the bow, measured at the shear (deck). The width of the boat at that location is ~10.5" at the deck so the frame itself should be about 10" at the deck.
The 12.5 does not have a notched plywood transom piece. See picture page 34 of the manual.
It is possible but unlikely that you got a mixed kit. If you have questions, give CLC a call during normal business hours and they will help you out.
