wood duck-----blistered glass & epoyy
CAN ANYONE OUT THERE ANSWER MY QUESTION SUBMITTED ON MAY 4, CONCERNING THE LIFTING OF THE GLASS & EPOXY IN SPOTS MISTAKENLY, ONLY HARDENER WAS USED, THEN I TRIED TO REMOVE IT WITH ACETONE, LET DRY, & USED CORRECTLY MIXED EPOXY . NOW FIBERGLASS IS LIFTING IN SEVERAL SMALL AREAS AFFECTED. WHAT SHOULD I DO ?
RE: wood duck-----blistered glass & epoyy
you know I've made so many mistakes with my build that I'm just going to leave the scars and get on with it, gives the boat a little character.
If you do a careful job with feathering the patches, the "scars" can be very nrealy invisible.
» Submitted by Fishbuster - Tue, 5/6/08 » 10:35 AM
The only thing I can think of is to cut out what is lifting, sand down to clean wood and patch it up.
This hull will be primed and painted. Patchwork would show through a clear finish.
Some lessons are learned the hard way. At least what is wrong can be fixed. That is very good news. Be happy.
Maybe a 2 color scheme for hull and deck would really make for a nicely finished boat.
- Joe.
