Suggestions for protecting WD12 bottom
I've only had my WD12 out a few times and already I've managed to ding the bottom pretty well. Most shores here in Puget Sound are rocky. What can I do to better protect the bottom?
1 reply:
RE: Suggestions for protecting WD12 bottom
» Submitted by Laszlo - Wed, 7/24/24 » 6:22 AM
What have you already done?
Rocks, especially big rocks, are tough to protect against. For rocks I've had best success with extra fiberglass. My go to is:
1. a single layer of 6-oz glass on the outside for abrasion resistance,
2. a layer of 4-oz glass over the entire inside of the bottom for impact resistance and
3. a 50:50 by volume layer of epoxy/graphite on the outside for slipperiness to discourage rocks from getting a purchase with sharp edges.
Glass on the inside helps with impact resistance because it resists the tension caused by a rock trying to poke through. It helps hold the wood fibers in place instead of letting them spread and open up. Epoxy/graphite is a lot easier to touch up than paint when scratched.
