I was rounding the edges and bottom line; i screwed up. While minor i know its there. I went thru the top layer on the edge and the more i try and make it even the more extensive it has gotten. Considering painting the edges on top and side like a race stripe. Would i paint first then epoxy or vice versa? I am awaiting more epoxy to glass the hull right now so if i am going to paint the time is now essentially. Cant believe i did this. This is my third build.
RE: Over sanded the wood
» Submitted by Laszlo - Sun, 11/17/24 » 5:35 PM
It happens to everyone sometime. All that experience does is make it easier to know what to do to recover.
Epoxy first, then paint. Never put epoxy on top of other finish material unless the manufacturer specifically says that your particular brand of epoxy and paint are compatible that way.
