kayak hoist
Well, my kayak is finished and tested and I just love it. Thinking about doing another one this winter. I wanted to thank all who helped me especially Jerry. I have one more question now. I need a place to store the boat and figured I could hoist it up to the beams of my lake home. Has anyone experience with these? Is the Harken one good from CLC? Will it raise the kayak to the point of touching the beams? Any help with this will be appreciated
12 replies:
RE: kayak hoist
Hi.  The last picture under "Sea Wolf Project" in my gallery shows how I store my boats, hung from the garage ceiling.  I use the rope/ratchet available at Home Depot.  The other strap extends the rig so I can reach it, to the the eye screwed into a 2X6" in the vaulted ceiling.  http://gallery.me.com/jermcmanus  Good Luck.  Jer, mtsailor
RE: kayak hoist
You should be able to make this work. Rated for 50 lb, but I think I'd get two, one for bow, one for stern. Maybe replace the line provided
http://www.amazon.com/Racor-PBH-1R-Ceiling-Mounted-Bike-Lift/dp/B00006JBL3/ref=sr_1_2?ie=UTF8&s=sporting-goods&qid=1252324741&sr=8-2
RE: kayak hoist
That's sooo cool!  I'm thinking 50 lbs should be perfect (as my  yak should weigh in at about 46!).
 Sweet, thanks for sharing,
Larry
RE: kayak hoist
There's a reason I suggested using 2; the aren't the best quality, so I would add an extra safety factor. One place actually speced 20 kg.
I'd hate to feel responsible for your boat, or whoever might be underneath.
RE: kayak hoist
I go as low tech as a person can get.  I use those rubber coated hooks one screws into the joist.  I assist the raising of the yak by lifting one end f the yak and pulling on the rope.  Goes up easy.  Tie off and do the other end.
RE: kayak hoist
I installed eye bolts through some reinforcement boards between the trusses in my living room ceiling.  This provides a very solid hold.  2 webbed straps keep the kayaks in place. We feed a rope through each of the eye hooks to form a sling at each end and simply hoist the kayaks up to the ceiling each fall.  Requires 2 people to hoist in place.  Takes about 5 minutes for each kayak.
RE: kayak hoist
Those kayaks look good against your cieling Chris. However, even if I had a wood cieling I doubt my wife would let the craft inside.
BTW I had fun at the Sacramento show yesterday and had a number of comments/questions about my Wood Duck.
RE: kayak hoist
This particular system: http://www.prohoists.com/Canoe_or_Kayak_Garage_Storage_Lift-_ladder appears to be nothing more than the lift system thak I use to hoist my bikes up in my garage, with just a couple straps to go around the boat itself.  I have seen the bike systems for under $20 now and am certain you could make your own straps.  That was my plan, once I get the WD12 fininshed....
RE: kayak hoist
Chris J,
 I don't really have much to contribute to this thread, but I wanted to say that your kayaks look beautiful, doubly so in with the audacity to display them almost as an art installation in your own living room. I know musicians who do similar things with their instruments (and take one or two down to play often) and I've often seen fake or unusable nautical instruments used, but this, real boats, displayed and stored as such, is awesome.
-- James
RE: kayak hoist
Reducing the load on each by using one bow and one stern should make it less likely there would be a failure. I'd feel better, especially with the load so close to capacity.
RE: kayak hoist
Jerry,
I was looking at your kayak pictures and I was wondering where did you get that skeg setup.  I'm building a redfish stripper and was thinking of building my own, but that is a really nice setup.
 chris
RE: hoist & Skeg kit
http://www.superiorkayaks.com/superiorkayaks2009_007.htm
The skeg I put in my Sea Wolf is listed on Superior Kayak's web site.  Ecxellent product!
Good luck.  Jer
