dealing with bends in a true 2x4 strongback
I just built a strongback from rabbetted MDF to 2" x 4". It has couple of little curves to it.
Nick's book is based on a "2x4" strongback and forms that have 2" x 4" holes, so you can true the forms on the strongback by taking advantage of the small difference, and shimming or using cleats. By building a true 2" x 4", I seem to have lost that option. I have no way to move the molds to accomadate the curves.
Did I just screw up the strongback bigtime? If I do it again, might I get it right? Should I try planing the MDF strongback to true (but no longer 2")? Should I toss this MDF strongback and go back to 2x4's, ala Schade?
 -Robert
RE: dealing with bends in a true 2x4 strongback
I had (have) the same problem only I made my 2x4 strongback our of 1/2 inch plywood.  I ended up wetting the plywood and leaving it out in the sun on a flat surface.  It straighten it out except on the every ends.  The strongback was 12 ft long I just didn't think I would ever find a 2x4 (lumber) any better.
I sanded the strongback with my belt sander, rounded the edges to create space for the forms.  I had to adjust the end forms, but the other forms lined up very well with just slims.
I read somewhere to use 3/4 inch ply the next time.
Mike
The quality of the materials may be part of the issue.  My current project, a dory, required a beefier strongback so I built the box from 3/4" furniture grade plywood.  It's very straight but would be too robust for a dainty kayak.  I saw a kayak strongback made of 1/2" ply at a local building expo.  The builder told me he'd made several 'yaks off the same form with no problems.  His was made of Baltic birch ply.
13 days
for Discount Code Savings!
Ranging from $30 - $250
