Cpl questions on Chstr Ywl scarf joints
Looking for reassurenece...
1. I seem to be running into the same issue that this guy had. The gap in the joint is not a consistant width when the two halfs are in position according to the measurements. Not too concerned though http://www.clcboats.com/forum/clcforum/thread/513.html
2. When measuring to the ends of the planks to the baseline, I assume I'm measuring to the edge of the wood, not the inside edge of the rabbet.
3. I'm fairly confident that I'll join the planks together correctly but it not, how much leeway is there for misalignment ?
Paul
