I received my plans for a 16, they talk about having 3/16 plywood, the only okoume plywood that i could get from around Montreal is a 1/4 plywood. Can I build out of it or it will be hard to give it shape?
RE: thickness!!
Salut J'aime les Bateaux,
I'm from Montreal too, and am currently building a Skerry. May I ask, where do you buy your plywood? I went to Langevin et Forest but I find them expensive.
I used 1/4" for the sides of the Skerry and I find it is easy to bend and give shape. When glued into the final position, it becomes very rigid and strong.
Jean.
RE: thickness!!
» Submitted by LarryMcInnis - Mon, 3/22/10 » 6:23 PM
j\'aime,
You'll find the 1/4" Okoume more appropriate for the 16 footer; the 3/16th inch wood will produce a lighter boat, but will be more fragile as well. My Chese 17 is 1/4" all the way round, and it went together great!
Enjoy, you're gonna love this!
Larry
