My MC 16.5 now looks like a boat. I found the stiching part to be enjoyable and it took my mind off the stress of business. So far, I have done everything without a helper and that includes stiching the sheer panels. Man those things were stiff.
I'm still building in our basement and I used two folding tables as a base. That definitely got the boat off the floor, but my lower back is still sore. I used two 24" bar clamps purchased at Harbor Freight Tools to keep the sheer panels from flopping around. I clamped the to each side of the table and just moved them down as I went. It made bending the panels around the shape of the hull much easier and I was able to do it without a helper.
The stitched panels looking toward the bow:
Looking toward the stern:
Side view of the stern. I hope this does not become a huge problem. The stiches are not tight and I can probably get this to match up a little better. A little trimming may be necessary.
RE: Annapolis, we have a hull!
The mismatch at the stern is a non problem. After you're happy with the hull's shape (square/plumb/fair/pretty/etc.) and have epoxied the hull together, trim it to suit. I hope you continue to enjoy the build and then the paddling.
» Submitted by jeffh - Wed, 4/14/10 » 12:26 PM
Should probably include a side shot of the bow. No, I didn't get angry and rip out the drywall. During all the heavy rains of 2009 in the Atlanta area, we had a basement leak. I had to rip out a section of drywall and carpet. The actual repair takes place tomorrow after more than six months of waiting. Business for basement leak repair was booming in 2009/2010 around here.
