Has anyone used thickened epoxy to fill tape weave?
I've added two coats to the entire interior portion of the boat. The fiberglass tape still shows some weave and I can feel the weave. There are also jagged edges on the weave which I assume I can sand down before painting. This will be a painted interior and hull with a bright deck. If I used a little cabosil thickened epoxy on the tape...would that be a problem?
RE: Has anyone used thickened epoxy to fill tape weave?
Thanks Laszlo. I've read posts about using phenolic micro baloons and should have known. I want to finish this step today, so I hope my local West Marine has the stuff.
So, my local West Marine did not have MAS phenolic microballoons. They did have West 410, which according to the MSDS is:
"Blend containing thermoplastic and inorganic microspheres" Microspheres sounds a lot like microballoons to me.
» Submitted by Laszlo - Tue, 4/20/10 » 11:38 PM
Yes. It would be very difficult to sand. Use phenolic microballoons, instead. The mix is lighter and much easier to sand.
Have fun,
