I've been working on the MC16.5 for just over two weeks now and the stitches come out today. That means, it's time to flip her and prep the hull for glass. I plan to paint the interior (probably white) and I need to make that purchase. Is there a good interior paint that will not cost me $50? I've already spent $185 on hull paint and varnish for the decks. But I will spend the dough if it's necessary.
5 replies:
RE: Interior Paint
It will be either in a covered boat slip out of the water or sitting inside on a pair of slings. For some reason, I thought epoxy and oil based paint would not stick. I guess a good primer over the epoxy and then the paint is the way?
RE: Interior Paint
Jeff,
I painted my interior with oil based exterior enamel..., no primer. Seems to have adhered quite well. I wouldn't add the weight (i.e., primer).
Larry
RE: Interior Paint
Primer's also good for getting a smoother coat, not just adherence. It finishes the job that you started with the fairing compound. Lay down a few coats of primer, sand it with a fairing board, repeat until it looks perfect or you've had enough sanding.
RE: Interior Paint
Thanks Guys,
I'll prime and paint the bilge area with some locally sourced paint. I have Brightsides paint for the hull and regular schooner for the rest.
RE: Interior Paint
» Submitted by JackD - Fri, 4/23/10 » 11:14 AM
Unless you are planning on leaving your boat open to the elements, just use a good quality oil based porch paint. I'm partial to Benjamin Moore. I used it inside my dory (which does live outside) and it's held up well for two seasons.
