Re: Design Advice
Posted by LeeG on Jan 22, 2008
www.kayakforum.com
you're more likely to get responses of people who've built them. I haven't been in either one but I'm guessing the Spring Run is bigger and isn't as maneuverable. If you're new to kayaking you might want more stability than the Guillemot has and about the same maneuverability for that usage.
In Response to: Design Advice by Mike Vettori on Jan 22, 2008
