Re: rowing books
Posted by Ron Paro on Feb 4, 2008
Greg,
WoodenBoat Sept/Oct 2007 (issue 198) has a very good article about one form of proper rowing technique referred to as the 'dory stroke'. A key component is blade orientation with the surface of the water as you go through the stroke. This issue is available for purchase on-line from WoodenBoat.
I am eager for warmer weather so that I can try it out.
http://www.woodenboatstore.com/prodinfo.asp?number=200%2D198
In Response to: Re: rowing books by greg on Feb 4, 2008
