Re: ROS with vac attachme
Posted by LeeG on Feb 27, 2008
it is a bit dicey using heavy enough grit to remove glass/epoxy and not fly right through the wood when the glass is gone. I like the vac as it makes the discs last longer removing a dusty and somewhat unhealthy mess at the source.
In Response to: Re: ROS with vac attachme by Jon on Feb 27, 2008
13 days
for Discount Code Savings!
Ranging from $30 - $250
