Re: epoxy concerns
Posted by Laszlo on Mar 1, 2008
Larry,
It's not so much weight, as pressure (lbs per square inch). That said, here's the setup I used to glue my Wood Duck 12 panels - those containers are filled with 15 lbs (20 in the big one) of kitty litter and are sitting on plywood panels to evenly distribute the weights. I use a similar setup every time I need to glue panels together.
http://www.morocz.com/BoatBuilding/images/04_GlueJoints_tn.jpg
In Response to: Re: epoxy concerns by larry brown on Mar 1, 2008
