Re: Clogged epoxy pumps
Posted by CLC on Feb 29, 2008
We use denatured alcohol or lacquer thinner to clean out the pumps here.
If you're pumps are coughing or jamming a lot, try keeping the epoxy warmer. I always used to keep a lightbulb pointing at the jugs of goo. Warmer resin is less viscous and thus runs through the pumps more easily.
In Response to: Clogged epoxy pumps by Mark on Feb 27, 2008
- Re: Clogged epoxy pumps by Laszlo on Mar 1, 2008
