Re: Clogged epoxy pumps
Posted by Laszlo on Mar 1, 2008
Warmer resin also sets up more quickly after mixing with hardener. On a cold day, this could be the initial push to start the curing process, but on a warmer day, this could be what causes a batch to kick prematurely. As long as builders are aware of theses things and plan accordingly, there shouldn't be any problems.
In Response to: Re: Clogged epoxy pumps by CLC on Feb 29, 2008
