Re: Severn questions
Posted by Ron Paro on Mar 12, 2008
James, CLC sells the 3mm okoume for $39.00 per 4x8 sheet.
CLC says: "We buy our plywood from several top European mills. Our prices are among the lowest around - 50 percent lower than some marine lumber yards - so even with shipping costs you can save a bundle. We stock 3 mm, 4 mm, 6 mm, and 9 mm 4� x 8� panels. This is the same wood we use in our shop. Shipping is 2-day air freight to most of the continental U.S."
From the Shopping Cart page: "Plywood: Up to 16 mm thickness to most zip codes, within contiguous 48 states of U.S. only -- $99. Please call to confirm rates and for large orders."
Buy 5 sheets of 3mm delivered to your door for $99.00, and build two boats for under $300 in plywood cost. (I don't know how much you need for a Severn, this is just a guess.) Ron
http://www.clcboats.com/images/building/marineplywood.jpg
http://www.clcboats.com/epoxy_plywood.php#plywood
In Response to: Re: Severn questions by James K on Mar 12, 2008
12 days
for Discount Code Savings!
Ranging from $30 - $250
