i started my first boat
i have a problem an i hope some one can help i laid out my first side the bottom then i cut an laid out the top as i was going i found out i needed to lay out both sides. i subtracted the bottom measurements an laid out the top will this work?
RE: lay out of the skerry
i am building from a plan.
when i made the strips for the bow i laid the bottom measurements out an cut the bottom
when i went to lay out the top the strip was not big enough. i realized after that i needed to lay both top an bottom out before i made a cut
so what i did i subtracted the bottom measurement an measured for the top cut. is that going to work
» Submitted by jf_poirier - Mon, 6/7/10 » 6:26 PM
Hi jab349,
I'm afraid I don't quite understand your question. Which step of the build are you at? Are you building from a kit, or plans? I'm sure if you clarified your question a little you'll certainly find the help you need.
Jean.
http://picasaweb.google.com/pbjsndwch/BuildingTheSkerry#
