So I decided to try a dry run and lay out the outer hull fiberglass on my 17LT. Unfortunately, I hadn't sanded the epoxy-filled chines yet. The fiberglass snagged on the rough epoxy in many spots and the fiberglass has what looks like small pantyhose runs in it. Will this be a problem once it's wetted out? Thanks!
