Wood duck bulkhead fillet question
Hi Folks,
I'm to the point where the manual says to fillet the space between the bulkhead and the deck. There is about a 1/2 inch gap. I think I should be able to pot and fillet the gap just fine. I'm wondering if I should also fiberglass tape joint after the fillet if made. The manual does not say to do this and there is not enough tape left over.
Thanks, Andy
1 reply:
RE: Wood duck bulkhead fillet question
» Submitted by atwoodyducker - Thu, 1/12/12 » 4:32 PM
I had some gap there also. Just fillets on mine. Took a couple applications to fill the void. I dont see any reason to glass that.
