carrying eastport pram on stanchions?
i'm about to add stanchions to store the eastport pram on the aft transom of our 33 ft sailboat. any suggestions on where to attach the davits' tackles at pram bow and stern ? i was thinking to run the tackles thru the cutouts in pram's bow and stern..
thanks
RE: carrying eastport pram on stanchions?
I think I would through bolt a reasonable size padeye, with a welded ring, on the inside of each transom. I would use another padeye on the exterior of each transom as a backing plate. The exterior padeyes could be used as an attachment point for a painter for towing, and at the stern it could be used for a stern anchor if you didn't want to drag the boat up on a stoney beach. I would place them just low enough so you could two-block the tackle on the davits, and pull the dinghy tight to the underside of the davits. I would also install some sort of drain plug, either in the stern transom or in the garboard, which I would leave open whenever the dinghy is in the davits. I saw a boat arrive in Provodenciales, in the Turks and Caicos, that had a wave hit dinghy in davits, and took the dinghy, one davit, and about 18" x 18" of deck and backing plate. I don't doubt that the Eastport will stay together, but will your davits and stanchions hold up?
» Submitted by John, CLC - Mon, 6/18/12 » 1:39 PM
From davits? My advice would be to through-bolt padeyes through the bottom of the Eastport Pram. Fasteners countersunk into the external bottom skids. This would be so strong that it will pass the standard dinghy-in-davits test: a dinghy full of rainwater.
