I started working on my Wood Duck 12 project this weekend and last night I mixed up the epoxy to join a puzzle joint and forgot to add the Cell-o-fill to the mix. Any long term effect? Is there anything I should do (other than not to repeat the mistake) at this point? Thanks, Rob
RE: Rookie mistake
I have done that on several joints, all are still holding fine. If it is a small joint you can still use a heat gun on it and separate it if you want and redo it. But, it should be totally fine. You could also just lay a piece of glass on the joint which would make it super strong. Never built a wood duck. Does that joint end up getting glassed over? If so, I would just move on after you fill any gaps.
RE: Rookie mistake
Thanks to you both. There is glass on one side of the joint (interior) already and the exterior will get glass later so I will look to see if there are any gaps and when I mix up tonight to do another set of joints I will fill as needed.
RE: Rookie mistake
Agree that this will not be a problem. Even if the joint is a little light on epoxy, it will get all that it needs when you glass over it.
As a matter of reference, on the newest designs like the Pretrel Play, the puzzle joints don't get any epoxy at all until you glass the hull/deck. They call for use of CA glue to hold the joint together prior to glassing.
RE: Rookie mistake
» Submitted by wing15601 - Tue, 1/20/15 » 11:29 AM
Epoxy/wood joints are pretty strong. The filler doesn't add strength to the joint but I believe it is there to prevent gaps which may occur because of absorption of the epoxy into the wood. I would go back to where ever you are building and check if there are any areas where the epoxy has been absorbed into the wood and mix a small batch to fill those spaces before the first batch is fully cured which I believe is maybe 24 hours or more. I think your puzzle joint will be plenty strong.
