11 months after my Skerry kit first arrived, the first container of MAS resin finally ran out. I unsealed the second container and moved the pump from the first to the second. As I inserted the pump into the second container, it felt like I was pushing the tube through wet sand. I had to work it a bit to get it all the way down. I was able to get a few squirts of resin out and, when mixed with hardner, it had the appearance of epoxy slightly thickened with cab-o-sil. (It hardened as clear epoxy, though) Anyone have any experience with a situation like this? What should I do with this resin?
Hooper Williams
Brevard, NC
RE: funny resin
this can happen to resin if it gets cold in shipping or storage. The best fix is to put the resin container into a bucket of very hot water for a while to heat it up. this will "melt" the slush and will have no ill effects.
RE: funny resin
Worked like a charm! First, I tried the hottest water from my tap. That had a positive effect, but not complete. I then boiled a big chili pot full of water, took it off the heat and set the jug in it overnight. When I came back, the resin was good as new.
Hooper
RE: funny resin
» Submitted by ruud - Fri, 2/6/15 » 9:01 AM
http://www.clcboats.com/forum/clcforum/thread/29987.html ?
Ruud
