After applying the tack epoxy on the hull and deck panels and putting the two halfs together, there is one area between the forward deck and bow panel that developed a slight overlap. The overlap is about 1/16 to 1/8 for a about one foot. BTW the rest of the kayak fit together perfectly.
Now that everything has cured, I am looking for the best fix. The way I see it is to sand the joint smooth and probably sand through the top deck veneer or to mix a solution of exoxy and wood flour and apply to the overlap and sand it down once its cured.
If I did sand through the veneer on the top panel, whould the error be masked by the darkening of the fiberglass cloth and epoxy along with the use of a wood stain scratch pen (used for furniture repair)?
Any advice is appreciated................
1 reply:
RE: WD Overlap issue
» Submitted by Laszlo - Sat, 6/20/15 » 2:17 PM
First, it's only an error if you didn't mean to do it.
Second, it would look something like this:
(the dark line at the interface between the deck and hull. The blotch below is actually my reflection while I was taking the picture).
3rd, if that wood stain pen is oil-based it would keep the epoxy from being absorbed by the wood, so don't use it until you've tested it on some scrap.
As you can see, I sanded my overlap away and decided that it wouldn't bother me in the least to have the dark line.As you see, I also left the stitch hole visible. The boat still floats. If anyone else is bothered by it, I say go worry about global warming instead :-) So far no one's been bothered.
Have fun,
