Fit of centerboard in trunk on NE Dory
Hi all ---
I have some concerns about the loosness of the fit of the centerboard in its trunk on the dory I'm working on. The trunk has a 1" wide slot -- the centerboard is 3/4 ". That seems pretty loose and would be banging around when the boat is under sail. I'm considering adding a couple of thin strips at the top of the centerboard to make the fit a bit tighter -- leaving about 1/8" of play. Thoughts?
Dave
RE: Fit of centerboard in trunk on NE Dory
Not to worry. You need that addtional space. The pressure put on the dadder board while sailing will take care of any slack. When on a beat, you'll have a hard time pulling it up I suspect.
» Submitted by Silver Salt - Thu, 1/21/16 » 6:35 PM
I had the same concern but settled on the idea CLC knows what it’s doing. Turns out the extra space is a good thing. When underway lateral pressure wedges the board in place and the extra space allows easy retraction when it gets fouled with rocks and mud. There is a little thunk on tacking that is kind of comforting. Same is true with the mast and mast partner, lateral loads lock it in.
