small 5 inch, 1mm wide gap. Should I be worried?
I've begun to sand and notice a few small gaps that are about 1mm wide gabs between two strips. They taper to fine points on both ends. the gap overal length is about 5 inchs. Do I do anything about it? Do I fill it with wood flour/epoxy? or just leave alone and let the epoxy fill it in while layin the FB cloth?
5 replies:
RE: small 5 inch, 1mm wide gap. Should I be worried?
Night Heron Hybrid 18. Deck strips. It is located inbetween two strips. Aparently I didn't lay the next strip tightly into the grove in that area so it left a small gap about 1mm or less wide and tapers at both ends where the edge of each strip joins back and tightly.
If I was worried about strength, I'd fill it with epoxy/woodflour putty. If I was worried about looks, I'd plane or sand a piece of wood to fill it in.
Good luck,
Thank you for the advice. Though curious, could you explain in laymans terms how to create a piece of wood smaller in width of a toothpick but as long as 5'' tapered? I can see the idea of making it stick out a bit then sand it flush, I get that part but how to make it narrow enough to puzzle it into the crack? Last question. I've heard that the woodflour becomes much darker. Though if I sand a stock of the same strip to make sawdust, wouldn't that allow it to match when mixing it with eopxy to fill it?
A guy could cut a wood strip as thin as able, then plane or sand it down as thin as needed from there. Just clamp a long piece to a solid work surface for the planing to take place away from the clamps. I have also been able to use a bandsaw to taper cuts down to even thinner than a toothpick.
As for the wood flour/epoxy color, my experience has always resulted in darker goop even when adding dust from the same wood species. If I was trying to color match to a light colored wood, I would try mixing in almost entirely cellulose on a test batch; that is one way I know of to end up with a light epoxy fill.
» Submitted by Laszlo - Tue, 6/7/16 » 11:30 AM
What boat, what strips?
