Wednesday is deck day for my Chesapeake 16. I do have two questions, how much epoxy should I mix and, after a dry run, how long should I expect it to take from start to finish for both decks. We will have two people working on this.
Thanks, Mike
RE: chesapeake deck
On my 17 we fitted the deck dry, adjusted straps, got nails ready and then glued it up. As with most large glue ups we worked as a team. Wife, the nurse, mixed the epoxy "exactly" and I applied it. This way small batches can be mixed without any pot time problems.
RE: chesapeake deck
» Submitted by Laszlo - Mon, 9/12/16 » 5:38 AM
When I built my wife's CH16LT I wasn't tracking my time by the clock, but I put the deck on as a dry run in an afternoon, let it sit for a few days on the boat and did the actual gluing in a morning. I'd estimate the actual gluing to have taken on the order of an hour or so, maybe less, based on the pot life of the glue.
I used straps and tape instead of ring nails. I was also working alone.
As far as the amount of epoxy to mix up, I did it in 3 oz batches using slow hardener. I don't remember how many batches it took.
Have fun,
