Passagemaker Plans Build - Parts Layout
In a previous post, I threatened to take an inventory of the parts of the plans on a sheet by sheet basis.  Here's what I came up with this afternoon for posterity after I set up the scarf joints to cure.  Note, still no shark fins...
PagePartThicknessQtyHalf/Full
Page 1/6Forward Bulkhead9mm1Full
Aft Bulkhead9mm1Full
Center Seat9mm1Half
Forward Seat9mm1Half
Mast Step19mm1Full
Bow Transom9mm1Half
Bow Transom Doubler9mm1Half
Bow Knee12mm1Full
Stern Knee12mm1 or 2Full
Aft Seat9mm1Half
Skeg9mm2Full
Daggerboard12mm1Full
Daggerboard Handles6mm2Full
Mast Support9mm1Full
Daggerboard Trunk Side6mm2Full
Daggerboard Trunk Spacers5/8"1 eachFull
Take Apart Doubler18mm1Full
Lug Rig Mast Partner9mm1Full
Lig Rig Doubler9mm1Full
Oarlock Riser3/4"2-4Full
Page 2/6Panel #26mm2Full
Panel #36mm2Full
Panel #46mm2Full
Panel #16mm2Full
Rudder Blade12mm1Full
Aft Transom9mm1Full
Aft Transom Doubler9mm1Full
Rudder Cheek12mm2Full
Gooseneck18mm1Full
Rudder Spacer12mm1Full
Yard Jaw18mm2Full
Page 3/6Amidship Frame9mm1Full
Motor Pad9mm1Full
Take Apart Bulkhead9mm1Full
Bottom Panel6mm1Full
Tiller3/4"1Full
Yard3/4"1Full
RE: Passagemaker Plans Build - Parts Layout
Uh, I was in the middle of trying to format the paste from the spreadsheet when my hand evidently brushed the touchpad which posted the message.  Sorry...  And of course you can't edit posts on this forum...
The spreadsheet is broken down into the 3 large sheets on the plans.  The columns are Page #, Part, Thickness, Qty, and Half/Full meaning is the part shown full size or is it divided down the centerline.
I'm going to try again on the paste/formatting thing:
Page           Part                       Thickness     Qty     Half/Full
Page 1/6     Forward Bulkhead        9mm               1         Full
                   Aft Bulkhead                 9mm               1         Full
                   Center Seat                  9mm               1         Half
                   Forward Seat                9mm               1         Half
                   Mast Step                     18mm              1          Full
                   Bow Transom                9mm               1         Half
                   Bow Transom Doubler   9mm               1        Half
                   Bow Knee                      12mm             1        Full
                   Stern Knee                     12mm         1 or 2     Full
                   Aft Seat                           9mm              1        Half
                   Skeg                                9mm              2        Full
                   Daggerboard                   12mm            1        Full
                   Daggerboard Handles     6mm              2        Full
                   Mast Support                   9mm              1        Full
                   Daggerboard Trunk Side 6mm              2        Full
            Daggerboard Trunk Spacers  5/8"            1 each   Full
                   Take Apart Doubler         18mm          1           Full
                    Lug Rig Mast Partner     9mm            1           Full
                    Lig Rig Doubler              9mm            1            Full
                    Oarlock Riser                 3/4"            2-4           Full
Page 2/6      Panel #2                        6mm            2             Full
                    Panel #3                        6mm             2             Full
                    Panel #4                        6mm             2             Full
                    Panel #1                        6mm             2             Full
                    Rudder Blade                12mm           1             Full
                    Aft Transom                    9mm           1             Full
                    Aft Transom Doubler      9mm            1             Full
                    Rudder Cheek                12mm          2             Full
                    Gooseneck                     18mm          1             Full
                     Rudder Spacer               12mm         1             Full
                     Yard Jaw                         18mm         2             Full
Page 3/6       Amidship Frame              9mm          1              Full
                     Motor Pad                        9mm          1              Full
                     Take Apart Bulkhead       9mm           1              Full
                     Bottom Panel                   6mm           1              Full
                     Tiller                                 3/4"             1              Full
                     Yard                                 3/4"              1              Full
Skully,
Why are you doing this? I'm genuinely puzzled by this exercise. If it's because of the missing sharkfin, you could just call CLC Customer Service and see if there really is a problem with the plans or if it's juat your set is missing a sheet. Probably a lot less work than this.
+1 on the lack of an edit feature.
First, I'm trying to contribute to the forum and make it easier on other builders.  I've spent probably an hour rolling and unrolling 16' sheets of paper to find specific parts (see my thread about trying to lay out parts on 36" wide paper on 48" wide plywood).
Second, I was just waiting for epoxy to cure at the end of the day, so thought it was worth spending a few minutes to document something that I haven't found documented anywhere else.
Third, I'm all about trying to resolve things on my own without engaging customer service.  I'm also on the West Coast, so time zones interfere with getting support for half the day.  I needed to make sure I hadn't missed it somewhere in the plans.  I wasn't even bad-mouthing the plans.
I already stated that I made my own shark fin pattern.  I've always respected your input and have treated you with the utmost respect as an invaluable resource on this forum.  Not sure why I seem to bother you so much.  I'm just a guy building boats and looking to share info both ways.  I thought that's what this forum is all about.  Not sure why I even have to explain myself.  Sigh...
Skully,
You took it wrong again.
I was just curious about why you were doing this, so I thought I'd ask you. I've never seen the CLC PMD plans so I couldn't understand why you were up to this. What you're doing here is a lot of work, I was missing the point so I was trying to fix that. I was asking you to explain, not to explain yourself.
Thank you for the explanation, it makes more sense now, Maybe it can make it into the plans package,
