My friend and I had just finished smoothing out the fiberglass and resin that go over the central two planks of the Chester Yawl (looks nice!) when my friend posed a question.
He said, "I know that we need to put some more 'glass on the bow and over several planks on the back 3 feet of the boat, but why isn't there 'glass protecting/reinforcing planks #2 and 3 the length of the boat? Those planks seem to be exposed as part of the bottom of the boat."
Can anybody help me out with an answer to my friend's question?
Dave
RE: Glass on the Chester Yawl
- Yes, absorbing some of the abrasion is definitely part of the concern. The glass strip down the center of the CY is a foot wide. Other than "added weight" why would you not lay down an additional strip of two of fiberglass?
If your question is why is the bottom of the boat reinforced with fibreglass but not the top, the answer is that the bottom undergoes more abrasion, both inside and out. Sure, you could put fibreglass everywhere, but that would add a lot of weight.
I do see that more glass gets applied on the interior of the bow and stern up several planks later in the process, which will provide more rigidity, not resistance to abrasion.
My friend's question did have two things that it was aimed at:
- abrasion resistance and the fact that the CY is fairly flat-bottomed (at least two planks are likely to make contact when pulled up on a sand/pebble beach.
- support - will running some extra strips of glass down the center of the hull provide any extra rigidity to the hull (and would that be a good thing?)
Thanks,
Dave
» Submitted by turnAround! - Tue, 8/6/19 » 3:07 PM
I turned over my wherry last week and the paint is scraped in the front and back couple of feet, on the bow and skeg. I think that this happens when I push the boat off and on the beach sand. More glass there will take longer to wear down to the wood.
