northeaster dory with spacered inwales
I have my bulkheads built and getting ready to cut 7/8" off of the top of bulkheads 1,2&3 (scary) to make rome for the spacered inwales. I can not find in the combined manuals the time to cut, but it seems like the time to do it. Before I stitch the hull together. Any thoughts?
Thanks Larry
PS: First time boat builder and very nervous.
5 replies:
RE: northeaster dory with spacered inwales
���Whoops. ...Be sure to cut off the inwales... not inhales or you will pass out
I cut them off after the outwhales were on. I used a router freehand. It worked well. I was a bit worried about cutting into the plywood but slow and steady worked well.
Rich
Thanks, that was my thought to cut them before I stitch it all together.
Larry
Larry,
Great decision. The spacered inwales add dramatically to the strength of a boat.
Happy Thanksgiving,
Dick
» Submitted by Meyer, Robert - Wed, 11/27/19 » 1:36 PM
��I've done it both ways and found it a bit hard to cut baulkheads after filleting them. I have a small circular saw (3 1/2 inch) using a guide stick to keep the saw level. I tried to cut them free hand and regretted it. I now cut them before installing them....be sure to only cut off the width of the inhales (of course you already knew this)
