�Well, got the hull tack welded today. On the 14 with the angle in the tailblock, the only way to get epoxy in the joints seemed to be with a narrow stick. There are several places along the hull where I had a fair bit of daylight between panels. The sides look fair, no hard spots, and I was reluctant to clamp or otherwise pull them tight together. On the skerry, this was not a problem. Between fillets and fairing, it was all good. Hopefully SUP will do likewise.
