A little goes a long way! If you're decanting what you'll be applying in a single session you need to measure carefully, maybe 1/2 - 1 tsp per 8 oz. varnish. A lot depends on ambient air temp. and that of your workpiece: warmer dictates a balance between working time vs. tendency to runs on non-horizontal surfaces.
RE: Ratio of Floetrol to varnish
» Submitted by spclark - Tue, 5/31/22 » 4:05 PM
http://sevenspaint.com/docs/tds/Flood%20Floetrol.pdf
Now Floetrol's meant for latex finishes, not oil-based. If using traditional UV-inhibiting oil-based varnish, you want to use Penetrol instead!
http://sevenspaint.com/docs/tds/Flood%20Penetrol.pdf
