T-Nuts or Well Nuts for deck line anchors?
I'm going to be using webbing for the deck line anchors on my Guillemot S but wondering if I should use rubber well nuts that can be inserted from the outside or go with T-nuts on the inside? I've seen some suggestion that Nick uses the t-nuts but havement seen any detail for how he installs them. Either way I will use the drill-fill-drill for the holes. Right now I'm leaning towards installing the t-nuts epoxied to the inside of the deck for a permanent screw hold. But the well nuts would be easier and replaceable.
