The hull will now be "tack-welded" with epoxy and cyanoacrylate glue (aka CA glue, aka "super glue"), so that the stitches may be removed. Mix up some epoxy thickened with wood flour to create a putty, and apply small dabs between the stitches on the transom, along the longitudinal stringer, and on either side of the center frame.
