I attached the deck to my Kaholo 12-6 last night. All seems to have gone mostly well in re: to gluing the deck to each bulkhead. This was my biggest concern. However, I did notice that in one spot there is some give. Directly above bulkhead #5 on the port side there is about a 3 inch section that gives about 1/8 inch when pressure is applied. On either side of that section it seems like the deck is secured to the bulkhead. Not sure if there was a dip in the bulkhead at that spot or if I didn't use enough epoxy there. In any event I was just wondering how critical it is to get this section glued down. Perhaps once glassed it won't be an issue? Any advice on how to glue it? I was thinking of drilling through the deck right at the bulkhead, injecting epoxy and then applying weights. Thanks for any help!
Patrick
RE: so close...
» Submitted by Wood_Ogre - Mon, 2/11/13 » 4:38 PM
yes drill small hole and inject epoxy resin apply weight. Epoxy should be thickend a little. you can get syringes from west systems , or hardware store in glue section. Or basting syringes in some super markets. Do so before glassing.
