How much paint and varnish?
My first build, a 17LT is coming along and it is time to think about finish.  My plan is to paint the hull and varnish the deck.  How much paint and varnish will I need?  Planning on using the Interlux products Brightsides and Schooner.  Thanks
RE: How much paint and varnish?
A quart of each should be plenty.  You will also need a quart of Interlux precoat primer to paint the hull with before you apply the Brightsides.
Consider using a marine urethane on the deck instead of varnish. It's shinier, lasts longer, half the cost, and much easier to apply. -Wes
