In the CLC website instructions on using peel-ply they say that it cannot be used on curved surfaces. I think they are talking about compound curves here. It seems to me that it would work OK on a simple curve, e.g., the outboard bracket demonstration on the same website.
Anyone who has used this stuff, please let me know for sure before I order.
27 replies:
RE: Peel-ply clarification
Thanks. I should have been more specific re the outboard bracket. John Harris demonstrates building one for the Pocketship.
Are you saying "nylon sport fabric" or rip-stop nylon is the same or will work the same as peel-ply?
Yes, those fabrics work the same and are almost the same as commercial peel ply. The stuff from the fabric store doesn't have a coating like some pp's, and the texture won't be as perfectly tuned as pp, but unless you're doing this for a living or needing critical secondary bonds without sanding, it won't matter.
But for that outboard bracket, I'd buy some clear mylar (art store for sheets, or McMaster-Carr for rolls) and use that for a much better surface finish, and a much more sure release. (or coat the mold in slightly overlapped layers of packing tape, and sand away the ridges during the paint process)
And while we're improving things...
Make the mold "male" instead of "female", out of 3/4" or thicker material, and round over any outside corners but don't bother to fillet any of the inside corners, and don't bother to coat the wood (or mdf or particle board or whatever is laying around and pretty smooth).
Make some cauls (flat slabs of wood) that fit the sides and top of the mold. The side cauls will have one corner radiused where it presses into the flange part of the bracket. None of these parts need to be coated, filleted, or waxed, so this goes together quickly and easily.
Lay a sheet of mylar over the male mold and trim it so it overhangs by an inch all around. Cut another to match, and then several sheets of glass to get the thickness you want (figure .0018 inches per oz of fiber for hand layup, and closer to .0014 if the part will be pressed, as here. So for 1/4" of glass, use 178 oz of fiber thickness (this is about the same as the 28 layers of 6 oz that the author recomended)).
But go buy a yard or two of DB1700 (17 oz biax) and save yourself the pain of all those little layers! Wet out the layers individually on a plastic sheet, using a squeegie to first wet and then remove excess resin, adding the first layer to the mylar (flat on the bench) and each layer on top of that, add the second sheet of mylar, then transfer the whole sandwich to the mold. Clamp the caul to the top (what will be the motor surface) with at least four c- or f-clamps, grab the outer layer of mylar and fold/bend the sandwich down around the mold, press the two side cauls against the outer sides, a little above their final location, lightly clamp them across the mold, then use some longer clamps to pull the cauls down toward the flanges which will stretch the mylar over the outside corners (which are fileted in the author's example), then increase pressure/add additional clamps across the cauls. You should see a fairly significant amount of resin starting to ooze out between the mold and the cauls, so anticiapting this you could wrap your clamps with tape and place some plastic under the work zone...
You can slip a wood chunk in the glass sandwich if you like, or just add an external piece that can be replaced as wear occurs.
You'll use probably 1/3 the resin the author did, your part will be very smooth on both sides (you still need to trim the edges to shape and sand those), and the part will weigh about 1/2 - 2/3's what the author's did. It'll also be stiffer for having used uncrimped glass (the biax, versus woven).
And you'll have some simple pressure-mold making experience that you can apply to a thousand other little boat projects!
That's a great plan! Thanks! Nemochad, can you advise on one point?
I need to make something of similar shape, so can follow your directions completely. However I do not believe it will need to be quite so stout, so was aiming for maybe 3/16 thick, and planned on using DB 1200.
The question is, will a 1/4 inch radius on the male plug be too tight for this cloth? I could increase the radius, but would rather not.
Again, thanks for the inspiration.
Others may elaborate, but peel ply is porus cloth through which the excess resin passes and is sopped up with rags or paper towels.
I've never used waxed paper, but have used sheet plastic (polyethelene?) With this, the excess resin needs to be squeezed out the edges of the plastic.
Obviously, peel ply is more expensive. But it does have more give, but still not much.
Now I am really confused: I thought peel-ply was the exact opposite. A tightly woven synthetic fabric that was impervious to resin. One just laid it over wetted cloth and it created a smooth surface where it rested on the wet epoxy. After cure it was able to be pulled off and reused since the epoxy had not penetrated the cloth and thus had not bonded to it. I never heard of anyone mopping or wiping up epoxy with rags......
I was planning on trying it out on my next project, but perhaps I have the wrong process in mind?
1/4" id is perfectly doable, IF you can pull the Mylar or pp covering tight over the od as you clamp the cauls.
pp is porous, and is not reusable. If clamping with vacuum or cauls, backing the pp with a layer of t-shirt cloth or thin polyester batting ("breather fabric" or "absorber cloth") is a great way to actively pull excess resin from your laminate stack.
Avoid waxed paper like the plague when working with glass and epoxy. It's just asking for trouble to introduce such a contaminant into your workflow. Mylar, or ordinary plastic sheeting works just as well as a release, without the risk of wax transfer.
For instance, here's a similar part on a simple male mold. The stack from the mold out is mylar (release), breather, pp, 1/8" or so of carbon, then mylar (for a gloss outer surface), then clamping cauls matched to the mold's shape.
There has been an insidious misuse of terminology rampant on the web. It's even worse than calling the process of bonding wood with epoxy "welding". The miscreant is "poor man's peel ply" and it is used to refer to polyethylene sheets, usually sold in DYI hardware stores for use as dropcloths.
There is absolutely nothing wrong with the stuff and I have used it quite successfully myself, but as Nemochad and Garland point out, it's the complete opposite of peel ply.
That term, poor man's peel ply, is probably where your confusion came from, Chester.
And Nemochad, all I get is a sign-in page, no mast bracket photo.
Oooooh! Pretty!
How'd you keep out the pet hairs? I notice a pet door there.
I would bet most of us are thinking of the use of PP not as a tool during a molding process, that is for the 1% of people that have that talent, I bet...wouldnt you agree that most people use PP as a smoothing agent to reduce sanding on flat surfaces on coats of wet epoxy, which can also be done (no doubt not as well) with 4 mil poly plastic ("visqueen") or wax paper...thus I understand the term "poor mans PP".
So with that clarification, can anyone compare the use of PP and plastic and wax paper as a product to smooth out on wet epoxy, reducing the time spent sanding?
For that purpose, pp will work better since it will stick to the epoxy better than plastic, leaving less voids. Again, I avoid wax paper (it also tears easily if you squeegee over it). Heavier plastic (say, heavier than 2mil) works fine on flat or non-compound surfaces, and can be squeegeed.
Adding pp to a fiberglass sheathing can save a bunch of weight, by eliminating the whole weave-fill process, and allowing/requiring modest squeegeeing to apply. Plastic can do the same, although you can't add resin through it to wet out drier spots, and plastic won't drape. I think pp is a very worthy addition to the workflow any weight conscious builder. It'll also save in resin more than it costs, if that is further incentive. It does add some time to the whole wet out process, so your resin green time needs to allow enough time. You can wet out say a third of the glass, add strips of pp almost to the dry edge, wet another third and catch up the pp, and so forth- I've done this alone when glassing larger hulls.
The cat door was for a stray, temporarily staying in my heated shop last winter. She (and the four kittens we later learned she was brewing) are now at the in-laws. Having a shop cat was fun, but required different work habits. No large panels of fresh epoxy left out to cure, sweeping up before leaving, and such.
Huh, the forum list says Diving Duck had the last post, instead of me, and I'm a "-"
Chad
- tried 4 mil plastic and found that where it was folded before being rolled for sale, the folds and even any small creases, it created a pretty good size lump in the epoxy even if I squeeged it out while wet.
With wax paper, being smoother with no creases, it doesnt leave any lumps and seems to work real well and in some pretty odd places like in the bulkhead slots in dory thwarts...tried plastic and it was too stiff to stay on.
The wax paper comes right off the next day, and I'm told it's OK to do another coat at that point with no sanding, but what is the point about wax paper being inheritly bad?
Thanks for any info, appreciate it!
Curt
Wax is the problem. If you gotta use wax paper, have a rigorous decontamination routine, some thing like acetone and alcohol before an abrasive scrubbing. (None of which can be done while the epoxy is green...)
Oh, OK...maybe the forum source of the info I was reading about wax paper was wrong, so you are saying if wax paper is used, to wait until it cures, and before applying another coat of epoxy to rub it down with alcohol and sand it? That sort of defeats one big benefit of using it to avoid sanding between coats and still have a real smooth finish.
The other use of wax paper I've heard about (and used) is to use it on the last coat of epoxy, and there naturally I would wait until it's cured and sand it
Well one more use is to go over cloth that has been wetted out...provided an amazingly flat surface and I was told it's OK to use wax paper in that application.
Any thoughts on those 3 uses?
Is my epoxy at risk where I used wax paper?
Fortunately the rest of my epoxy work can be rolled and tipped and thus I wouldnt see the need as much for wax paper, or plastic, either one eh?
Sanding a wax contaminated surface can just spread the wax around, and even drive it into the newly keyed surface. Always clean the surface first, then sand. Check the surface by wiping with water and making sure it doesn't bead.
Wax (paper) doesn't bother the coat under it, just every subsequent step. The next coat(s) of epoxy, paint, or varnish is likely to fisheye, bubble, or even lift.
Nemochad,
If you take too long to type in your response, your name is deleted. Don't ask me why.
+1 on no wax paper. I've been posting against it for over 10 years here, but people still want to give it a try.
And good karma for taking in strays.
All,
The best alternative to peel-ply that I've run across is paper towels. I got the idea from a builder who posted here about using toilet paper on his model airplanes. Paper towels were sturdier and more absorbent.
Basically, you wet out the glass as usual, then lay paper towels on it and gently push them in place. Leave them until they've soaked up all the resin that they'll hold (1 minute or less) and gently peel them off. This will leave bubbles and patterns on the glass, so immediately tip it out with a foam brush.
What this accomplishes is blotting any excess resin (like peel-ply) so you don't have to worry about floating the glass or having uneven bumps to sand off. It also increases the glass to resin ratio, making a lighter stronger layup. It does not leave a smooth matte surface like peel ply does. Instead, it leaves a prominent weave that's ready to fill with either fairing compound or more resin. Here's a panel on my schooner that shows the kind of surface that paper towel blotting leaves.
Larger image at http://www.morocz.com/BoatBuilding/images/schooner/10_PuzzleJoint.jpg .
Good luck,
>>>>>In the CLC website instructions on using peel-ply they say that it cannot be used on curved surfaces. I think they are talking about compound curves here. >>>
Just so. Anything that curves a lot in two directions---like the hull of a strip-planked kayak, say, would be impossible with peel ply. It's not stretchy like fiberglass. But if it's a "flat" 2D curve, no problem.
By the way, Chad, that's some beautiful carbon fabrication a few posts up.
Thanks, and, I beg to differ! By cutting slits or gores in the fabric (think mercator projection of the globe, if that helps), or just cutting it into strips beforehand (I'd guess 18"-24" for most strip kayaks, smaller at the ends), the very modestly compound shapes of a kayak will be no problem. Here's a *much* more greatly compounded shape (small sailboat cabin top):
I understand the company policy being reluctant to endorse a complication like this, and I'm just presenting it as an enhancement for folks that really want to save weight and are willing to spend a little time procuring and learning and applying this extra tool in the toolbox.
One other procedural enhancement that I think anybody can apply is to wet out things like tape or other small/local reinforcements on a bench on some plastic, using an auto-body spreader instead of a brush, and somewhat firmly (low angle modest pressure) squeezing out the excess from the cloth. Then, carry the wet tape to the boat and press and work it into the corner (which has already had epoxy freshly brushed on and the fillet still at least green) with your gloved fingers, and maybe some light teasing with a brush. Basically, avoid using a brush to wet out cloth whenever possible --whole-cloth sheathing on vertical surfaces being a notable exception. This will get you to the same place approximately as Laszlo's absorbent dabbing technique. Ah heck, while we're going crazy enhancing... those tapes and reinforcings (probably more applicable to bigger boats with either biax tapes or heftier weaves) can be wet out on pp, then the two carried together to the boat and applied to the seams. Pp or just the plastic on the bench you're wetting-out on also works especially well to carry bias-cut cloth from the bench to the boat, where the cloth would ordinarily turn into an unmanageable stretchy mess.
-Chad
Now you have me concerned that I used wax paper on some surfaces. So I did a test:
Last night I put first coat of epoxy on the daggerboard trunk with a brush and tipped it, (no wax paper) but the surface this morning has no drips but is pretty rough and needs sanding. I just went out there and water does bead up on it a little but not much. I wiped some alcohol on it and basically no change in the slight beading of water.
Last night I also put the last coat of epoxy on the mast step brushing it on and putting wax paper on the top and sides and smoothing it out. (no wax paper on the inside). Just went out and no matter how much I rub the top of the mast step with alcohol, water still beads up a lot on the mast step where I used wax paper and not as much where I didnt use wax paper.
So, I'm convinced, I wont use wax paper on epoxy but what do I do with the surfaces I epoxied where I did use wax paper? Go ahead and sand after rubbing with alcohol?
Curt
For a known wax problem, I use acetone first, using paper, disposable rags. This used to be all you needed, but with the solvent companies using reclaimed sources more and more, today's acetone isn't always as clean as it used to be. So I wipe with alcohol next, then scrub with water and a scotch-brite pad. (Note, for the wax-like amine blush that occurs with some epoxies, use just the water and scotch-brite.) If recoating with epoxy, sand to 80 grit for structural stuff, maybe just 120 for a plain coating.
You can skip all this solvent stuff by coating/bonding wet-on-green epoxy. Blush, if it occurs, seems to happen in the final green-to-hard curing stage. And, while it is still green the epoxy has free molecules to bond to those in your new coat. (Don't let this be a big deal for your work flow, though- an 80 grit sanded surface provides a really good mechanical bond.)
Just before adding a paint finish, I use one of the paint companies' really gnarly solvent wash products to be extra sure any wax is gone.
1) The mast step that water beads up on is going to be varnished and I had planned on sanding with 80, 120, 220 and setting it aside in the to-be-varnished pile. Is that OK?
2) The thwarts will be varnished where I did wet on green and used wax paper have already been rough sanded. OK to go ahead and do 120, 220?
3) On the boat floor, which will be painted, where wet on green and used wax paper, almost all of it came out great but I have a few of these:
1- Wash it first: acetone, alcohol, abrasive pad and water; then sand.
2- Same again, and I'd repeat the washing steps after sanding. (can you tell I place a high value on washing, and realllly dislike wax anywhere near my projects???)
3- If they are trapped under glass (that's what the pic looks like) they *probably* won't be a problem. If you can press them with your finger tip and make them move, I'd dremel (or abrasive stone in a drill) them to open them up a little and dab some epoxy in/over them. Doing nothing, worst case would be slight pimples that show when the paint is on, after the first hot day in the sun.
Chad,
Thanks for answering my questions, as well as the others.
Lot of good info here.
Might be a bit of a learning curve, but I can always use the mold for a second try!
That 24 hours is a serving suggestion. Check the data from the epoxy manufacturer. System 3 SilverTip, for example, can go 3 days between coats without sanding.
» Submitted by nemochad - Tue, 11/26/13 » 3:01 PM
I don't know about your outboard bracket shape, but:
Peel ply won't conform as well as thin glass, correct. For kayak hull type shapes, you might need to cut darts in the sides, or cut the pp into 18" stripes across the hull, with slight overlaps. It will go over the corners (chines) just fine if they're modestly rounded.
It's perfectly acceptable to piece the pp together, in whatever patchwork pattern makes sense to get things covered. Just avoid the factory edges on any of the inner layers where there are overlaps- they're lumpier than a cut edge.
For small projects, a local fabric store is a good source. Look for "nylon sport fabric", or ripstop nylon, prefereably white, and expect to pay $4-6/yd. For larger progects, a composites shop will charge $3-4/yd and the stuff will be rolled instead of creased/folded, but you'll pay for shipping.
Good luck.
