Refinishing my Kaholo - any tips?
My Kaholo is now looking a bit worn from 3 years of service and I'm thinking of refinishing it. I'm also hoping to correct some of the mistakes made when I first finished (like not realizing the varnish had a golden tint to it!) Is there a safe/best way to refinish a board? I was going to use the finest sandpaper I can find on my random orbital sander and gently sand it down and then apply new paint and varnish.
1 reply:
RE: Refinishing my Kaholo - any tips?
» Submitted by Charlie C. - Wed, 6/17/15 » 12:00 AM
It sounds as if you are right on track for refinishing your Kaholo. Every Spring I refinish my board. I remove all the hardware, give it a light sanding and refinish it.. I use a random orbital sander non the flats with about 22o grit and hand sand the edges, shear and chine being careful not to cut through to the resin/glass. I have not varnished any of my boards. Instead I use a clear linear polyurethane. I like Awlgrip products. Some of the Awlgrip products are three parts. Awlgrip has a new product called AWLWOOD which is single part and perfectly clear. You can put it over old cured varnish. It is very durable. check it out. I apply with a foam brush. Between coats I sand with a Scotch Brite pad.
