Ana. Duel Wherry deck and #1 bow gap
Starting to stitch. Bow deck and #1 has a 1/4 inch gap starting from contact with blunt bow point and slowly tapering to nothing about halfway back. Is this normal? Looks like if I taper the bow point the gap would close.
1 reply:
RE: Ana. Duel Wherry deck and #1 bow gap
» Submitted by Simpsonboater - Wed, 4/29/20 » 4:05 PM
Early days then! Yes once you start to get the sides building up and the bulkheads in it will draw up together. Please check your bottom panel to panel 1 is even along both sides as it caused a slight stern twist in mine.
Good luck, just about to fit rails here.
