Second boat advice?
Hi all,
Having just built my first boat (Eastport Pram), I started thinking—purely hypothetically, mind you!—what should my next boat be, if I ever get around building it.
I am curious what you guys think about it, so let me set some requirements. I am looking for a sailboat, and would strongly prefer not to have a motor (fortunately, all CLC boats accomodate the latter requirements easily). My primary sailing grounds are Boston Harbor. Usually just 1' wind waves, occasionally 2-3', but a lot of random wake from all kind of motorized craft. Winds anywhere from 1 to 25 knots (and more, but I can skip those days). Tidal currents mostly about .5 knots, but sometimes 1-2.
I'd like to build a boat mostly for daysailing with 2-3 people and occasional 2-3 day overnights with 1-2 people.
CLC boats that look potential candidates to me are Northeaster Dory, Southwester Dory, and Lighthouse Peapod. What do you guys think? Or maybe neither?
Also, are there any Southwester Dory builders or owners on the forum? It looks suspiciously underrepresented...
RE: Second boat advice?
Given that you're contemplating multi-night overnights, I should think the Southwester Dory might be the best fit, though I imagine it represents the largest commitment of time, resources and space to build, at the risk of stating the obvious.  John Harris describes this as a "capable expedition boat" which I don't doubt.  The rig--either a yawl with a large mizzen or a ketch with a small mizzen, however you want to categorize it--should be a handy thing, if my experience with my old larger, heavier Sea Pearl 21 cat ketch is anything to go on.
You should be able to row her well enough to manage without a motor, something I did with my Sea Pearl for most of the 22 seasons she had me.  It might be a lot of boat for a single oarsman at times, but, if you like to row and if you are good at sailing upwind, you should do fine without it.
Mind you, the motorwell arrangement is a brilliant piece of design work and I imagine she'd carry and use a small motor way better than most other small sailboats whose motor arrangements look like, and generally are, afterthoughts.  As long as you're good at working with wind and tide, and not looking to cover a lot of miles on a schedule regardless or wind and tide, you'll probably have more fun going motorless.
Mind you, this is just be speculating here...and maybe wishing I had something like my old Sea Pearl again.  Hopefully, somebody with actual experience will chime in here to give you more than my idle ramblings.
   Gramps,
This all makes sense, thank you!
Southwester Dory, actually, is the last boat where I would want to use motor, because the motor well takes valuable space in the cockpit. From what I can tell, the boat will look much better without it.
You raise good questions about rowing, though. My original thought was to only use it to get out of the harm's way (no wind, and drifting onto rocks). I am emphatically not looking to cover a lot of miles on the schedule, that's not what sailing is to me.
I wonder now if it's possible to row in Southewester with the sails up (same questions applies to the other boats, actually). Looking at the photos, it is gotta be pretty awkward.
I am curious about Sea Pearl. I did some googling around, and people are complaining about its inability to point high. Was that your experience? Again, I wonder how Southwester does in this regard. Northeaster with lug rig, too.
I never had any trouble getting my Sea Pearl 21 to point well, if it wasn't getting rough and blowing sixes and nines.  In a decent breeze without too much chop, she'd easily tack within 100 degrees if the sails were set, trimmed and handled correctly.  The main trick was to recognize that the mizzen was a significant proportion of the total sail area, but it has to work in the backwind of the main (the forward sail).  If the main is trimmed to sail as close to the wind as possible, the mizzen will have to be sheeted in more than is good for its contribution to forward drive, in effect "pinching" her.  By giving her half a point more off the wind, sheeting the mizzen to achieve its optimum drive and then trimming the main a bit farther off so it didn't backwind the mizzen, she'd generally more than make up the lost ground by the gain in speed.  This is pretty much true of ketches in general, as the late Phil Bolger would often point out.
Actually, that isn't just a theory.  Once, sailing aboard our Menger 19 catboat (a very weatherly boat) in company with my son in command of the Seapearl, we covered the same four miles or so straight upwind--the catboat in three tacks, whereas the Sea Pearl needed five.  However, the Sea Pearl covered the distance several minutes ahead of the catboat by giving up a bit of pointing to foot faster.  Watching many other Sea Pearl sailors over the years convinced me that over sheeting and baggy sail shape due to suboptimal outhaul and vang tension were the chief culprits in cases of poor upwind performance.  Expereince at the helm comes into it, as well; one needs to get the feel of keeping the boat "in the groove" when sailing hard on the wind, reacting to the subtle changes in wind speed and direction as you go in order to keep things moving along well.
The mizzen on the Southwester isn't quite as large in proportion to the main as with the Sea Pearl (more of a yawl, as John Harris points out), but I expect it'd be much the same thing as far as not trying to sail quite so close to the wind as one might with a high-strung sloop.  As for balanced lug sails, my experience with my lug rigged Passagemaker Dinghy has convinced me that the rig can be quite weatherly once one understands what makes it work and how to set and trim it to get the best out of it.  Seriously, that little boat has surprised me with her speed and weatherliness with Doug Fowler's masterfully cut lug sail.
As for rowing with the sails set, my experience with the Sea Pearl eventually taught me that there wasn't really much point to it for anything more than a few strokes here and there.  The 21' boat was a handful to row as it was without all that distraction.  With two modestly sized balanced lugs, it should be pretty easy to lower the Southwester's sails and bundle them off to the sides and out of the oarsman's way to allow effective rowing, and equally easy to reset the sails if the breeze comes back.  In my Passagemaker, if I think she'd get me where I need to go better under oars, it is child's play to switch from sailing to rowing, even striking the mast altogether if it looks like a long row in prospect.
I think you're right about the motorwell.  It would take up a lot of room, and is probably best left out if you haven't bought into the common fallacy that it isn't safe to venture out without one.
Again, I'm hoping someone with actual experience in the boats you're considering will chime in here to give you more insights.
14 days
for Discount Code Savings!
Ranging from $30 - $250
