fitting a Piantedosi seat onto an Annapolis Wherry
Hi
I've just finished building an Annapilis Wherry from kit, and realised that I may need to be able to shift the seat forward when rowing with a passenger sat on the stern, so as to keep the center of gravity roughly the same as when rowing solo. Has anyone built some kind of two-position seat support to accomodate this?
thanks
1 reply:
RE: fitting a Piantedosi seat onto an Annapolis Wherry
» Submitted by Rowme - Sun, 6/9/24 » 8:56 PM
Not sure if the set up is close enough to allow the same adjustment but the Expedition Wherry allows for the seat system to move 8" or so. Watch the Expedition Wherry video at 3:56 minutes and see if that will tell you aything.
Maybe reask your question through the CONTACT page to get a specific answer. I'm sure they can tell you.
