I am considering building another CLC boat this winter. However, this time I will be workiing in a basement, not a garage. I have a nice sraight shot to the outside, but I need to build a boat that, turned on its side, is no wider than the exterior door.
Can any of you builders / owners out there tell give me the dimensions from the bottom to the highest spot on the gunwale for the boats I am considering 1) Lighthouse Tender, 2) Chester yawl, 3) Jimmy Skiff, and 4) Mill Creek 13?
THANKS, Ray
RE: gunwale height
Lazlo,
The info is much appreciated. I gave myself a dope slap for not noticing that info at the bottom of the boat page, after years of looking at CLC boats.
Thanks,
Ray
RE: gunwale height
» Submitted by Laszlo - Mon, 5/27/24 » 9:42 AM
One of the most helpful things that CLC does is provide the minimum clearance space to get a boat in and out of a shop. It's typically at the bottom of the sales page for each boat labeled "Window Size Requirements". So from the bottom of the pages for the boats you requested, here they are:
Lighthouse Tender Peapod
Chester Yawl
Jimmy Skiff II
Mill Creek 13
