I have the piantedosi sliding seat rig and the dreher oars. The oarlocks seem to be the Concept 2 ones? Anyway I have the thing assembled pretty much.
When I put an oar into the lock, there seems to be a lot of play, like a half an inch or more... is this normal?
Also, for you wherry guys, did you have to drill holes in the rail for the bolts that attach to the boat? There are captured nuts in the rail but they don't line up with the recommended bolt locations.
Any help is much appreciated!
RE: Sliding Seat Rowing questions
I did have to drill holes in the rail in order to fit it to the boat. It wasn't a big deal, though it made me wince a bit. I bought two SS bolts that drop into corresponding holes in the seats and tighten down with wing nuts. I also put a couple of pieces of cork drawer liner on the bottom of the rail to keep from scuffing up the seats too much. Works fine.
Thanks for the info. I'll check out the youtube video.
Drilling those holes is going to be the hardest part of this project, mentally anyway!
Thanks again!
» Submitted by Rowingman - Mon, 4/12/10 » 9:45 AM
