Oxford II construction hitch: deck to forward coaming
I'm a first timer. I'm attaching the coaming to the rest of the boat. The foredeck is not arched enough where it joins the hull sides, so the deck does not easily come flush to the forward coaming pieces. I places some spacers on the inside (b/n seat and foredeck) to approximate the two pieces while they were stictched and glued, but the AC welds popped the moment I cut the stitches. Can I heat the side hull / deck seam to relax the angle? Install fiberglass tape on the inside of that seam? Other ideas?
